devo
hairy old fart
For some silly reason Triumph decided on the later models of the america and speedmaster (mine is 07 )to change from a painted finish on the fork lowers to a raw ali look with clear coat over, probably to save a buck or two,as I can clearly state that the finish quality on my 07 isnt a patch on the 04 speedy that I had.
Anyway,wot happens is,the clear coat looks fine until you get a couple of stone chips in it,then the moisture gets behind it and it starts to blister and look horrible
Anyway,after looking at sea dogs fork polishing job,I figured it was time to get on with it.
up close
a quick hieght reference shot for re assembly
see wot you made me do SD
after removing the bulk of the clearcoat with paint stripper,I've given it a run over with a stripping wheel in the electric drill.
next step is buffing with the various polishing grades.
To be continued.
up close
To be continued.
