Wire-Wheels
You might want to put a fresh set of plugs in it now that it has a functioning ignition. They are probably somewhat fuel fouled. Also on these T-3 engines, be careful not to overwork the starter. Make sure the battery is fully charged before you crank it much. It is easy to damage the sprag clutch with excessive cranking.
