4 Way Hazard Warning Lights.
Congrats to the both of you TUP TUP
Super job you did Tony TUP TUP
Ok, now that I've looked at the PDF. . . The above will not work.
On this photo
The Green wire and the Black wire coming from the Turn Signal Switch OR the Black wire at the left and right turn signal are what you will use to get the 4-Way Flashers. You will need to add a jumper (on/off) switch between EITHER one of these pairs. You will have to use the turn signal switch and the new switch (jumper) to have all four lights flash.
As I said before, I'm not an electrical engineer and only had to qualify as a 2nd Class Electrician 18 years ago. I've not had to use the electrical skills very often in those 18 years so I'm a bit rusty. IF my electrical engineer is back at work tomorrow I will run this past him. If he's not there I have a Master Electrician I can contact for his input. I'm determined to get this figured out. But as said earlier, I did stay at a Holiday Inn Express.
Sent from my iPhone using Tapatalk
Hi Guys,
Thanks for the simple and great solution.
What kind of a switch do you suggest for using as a jumper switch - would be great, if you can provide a specific one that can mounted on a handle bar.
Thanks,
Any Single pole, double throw (SPDT) switch would work to tie the sides together.
yhst-60311661257484_2336_3129175497
But for bike use I would a waterproof or marine switch. The easiest switch to fit on the handlebar would probably be a bike specific switch.
I'm not sure what switch Garry may have used, I'll let him answer as to the specific switch.
Samar,
Below is the one that I bought off of Amazon, it's been fine since the day that I fitted it and it works perfectly. It wasn't expensive at all
Motorcycle ATV Bike Handlebar Accident Hazard Light ON OFF Kill Switch Button: Amazon.co.uk: Sports & Outdoors
You can also get the same switch on e bay ( I bought one as a spare )
Motorcycle ATV Bike Handlebar Accident Hazard Light ON OFF Kill Switch Button M3 | eBay This was even cheaper.
Or even this but this kit is not cheap at all
Motorcycle Hazard Warning Lights. Four Way Flashers | eBay
Hope that this helps
