Went to go for a ride yesterday, shifted into 3rd gear and got noise as if the transmission was eating itself up. 1st, 2nd, 4th and 5th go into and out of gear just fine. Then, you hit 3rd. Needless to say I got the home as quickly as possible. If I put 1/2 mile on her, I would be surprised.
Put the bike on the stand, strapped her down and turned her on. Went from neutral to first, every thing ok. Shifted to 2nd, just fine and dandy. Got to 3rd, yep, the noise started. Up shift to 4th, slick as can be. I went to 5th to make sure I didn't have a problem there. Nope, only 3rd gear. As I had it on the stand, I went back to 3rd and walked around to the right side of the bike. That's how I found the chain slapping.
My chain was slapping on the bummer pad on top of swing arm as the chain entered the counter sprocket cover. I went through all gears again looking at the chain in each gear. It is only 3rd gear that produces the slap.
Yesterday was the first time the chain slap appeared. On previous rides this spring there wasn't any slap in 3rd gear.
I did check the chain tension and it's right where it should be.
How does a chain slap in only a single gear? More importantly, how does on make it go away?
The bike is a 2010 Bonneville SE.
