I hope late this summer. I have a bunch of unexpected stuff to do.
"I've seen worse"Wow! Is much of the ugly salvageable? Looks bad, but how bad is it?
I bought a gallon of Muratic acid, put the rusty parts in a plastic tray deep enough for the parts, then SLOWLY poured in 1/2 gallon of it, taking care not to let it splatter, and placed a piece of plastic siding between myself and the parts just in case. I let them sit and sizzle a few minutes then I dumped (5) 5-gallon buckets over the tray, one after the other. About the 3rd one, the acid was dissipated, but I kept on "just in case". I don't need to lose my fingerprints to keep from being arrested, so didn't feeling like dealing with acid burns for no good reason. That stuff is a whole level nastier than battery acid!Can you describe the acid bath process a bit more?
I've never gotten to the point to use muriatic acid, but remember a shop where I worked in my youth had some. I suspect for the same purpose. It doesn't do anything but remove the undesirable bits? Is the few minutes an experience derived number? Thanks for the description.I bought a gallon of Muratic acid, put the rusty parts in a plastic tray deep enough for the parts, then SLOWLY poured in 1/2 gallon of it, taking care not to let it splatter, and placed a piece of plastic siding between myself and the parts just in case. I let them sit and sizzle a few minutes then I dumped (5) 5-gallon buckets over the tray, one after the other. About the 3rd one, the acid was dissipated, but I kept on "just in case". I don't need to lose my fingerprints to keep from being arrested, so didn't feeling like dealing with acid burns for no good reason. That stuff is a whole level nastier than battery acid!
Hardly.I've never gotten to the point to use muriatic acid, but remember a shop where I worked in my youth had some. I suspect for the same purpose. It doesn't do anything but remove the undesirable bits? Is the few minutes an experience derived number? Thanks for the description.
Hope you’ll post more pictures. I’m hoping to learn.Hardly.
I figured "that ought to do it" before the gears started melting!
All of the rust and 98% of the crusty flakes are gone, but there is some staining that may be permanent (not the fault of the acid)
I was working in the middle of a cleared spot of land on my property out in the country, where there is no risk of the run-off affecting any wildlife or vegetation (dirt runway ultralight airfield). The dissipation took up a good amount of space, like a large parking place for a vehicle. So, if you don't have a proper way to contain the rinse phase, "don't try this at home"...Hope you’ll post more pictures. I’m hoping to learn.
I recall the shop I worked in gathered the waste in hazard disposal containers and the process was also in a special vat with drain to said containers. Yes, not going to try it at home. LoL. Just want to know as much as possible. I like to know what I'm asking someone else to do and what to expect if I need to bring items to some shop. They might even recommend some other method.I was working in the middle of a cleared spot of land on my property out in the country, where there is no risk of the run-off affecting any wildlife or vegetation (dirt runway ultralight airfield). The dissipation took up a good amount of space, like a large parking place for a vehicle. So, if you don't have a proper way to contain the rinse phase, "don't try this at home"...
