07 speedmaster, starter windes over but not starting. Replaced coil pick up, adjusted to 0.8mm, replaced CDI with Procom. Peplaced coils and spark plugs. Had started but wouldnt rev over 2500RPM THEN CUT OUT. Un plugged taco/dash, engine started and revd. Pluged back in wouldnt rev. Found sidestand switch at fault. Bypassed switch, connected dash all went fine. Took for test ride, around 40kms, went fine didnt miss a beat. Turned off started straight away. Waited 1hr, started ok. Next morning started fine and warmed up. Went to get ready for big ride, come out about 1/2hr later, no start no spark. Checked pick up, ohms reading ok and getting pulse. This has been going on for months. Had wiring apart, checked condenuity between all pugs. New pick up, coils, CDI, spark plugs. Tested coil leads are fine. Im a Mechnic, not Auto elec but know a bit. Just at a loss!
