Hi everyone
I recently did a complete nut and bolt rebuild on a T140V 1976.
I tried to start it first time and it fired up right away at 2nd kick. I did a test drive and after half a mile it started dying out on me and became really hard to start. I attributed at the time to the carbs running rich and having spark foul. I would clean the sparks plugs and it would fire up again. Eventually I noticed that I had some white smoke from the left cylinder and ended up rebuilding the top part of the engine again. Turns out I didn't aligned the segments properly on that side. Once I sorted that out the bike restarted again but when I would open the throtle and tried ride it it would die on me. It would also backfire mainly on the left side and seemed to flood with occasionally spitting fuel from the back of the carb. After that I hit a wall and could start it I would just flood the engine.
The carbs seemed well set with the exception of the old floaters and needle valves plus the needle jets were 210 while they should be 190 from the specs.
Ended up ordering new needles, needle jets, main jet and a stay up float kit and valve. Put it all back together and set the fuel level to 0.21´´ plus new set of spark plugs. tried to start it and again had back fire from the left cylinder but no start whatsoever. Checked the valves several times and they are in spec and also I have spark.
I am running the Boyer electronic ignition with a power box and battery. have the 11.9 volts on the battery.
Getting really frustrated with this and I am running out of ideas!
Any thing you can see that I´ve missed?
Cheers
Miguel
Cheers
Miguel
