Unit 650, Triumph added a ninth bolt through the head into the block between the cylinders on the exhaust side. 750 upgrade kits have the thread in the block for this.
73 on 750, Triumph added a tenth bolt through the head into the block between the cylinders on the inlet side.
Afaik, increasing a Triumph twin's capacity beyond 750 is not done by increasing the bore i.d.:-
. early 73 750 are 75 mm bore, barrel casting thickness is increased near the base to allow 76 mm;
. practically, increasing a Triumph twin's capacity beyond 750 is done with a Norton 89 mm stroke crank.
