hemibee
Texas Tiger
If you're going to mount it to your ATV seat prior to mounting to your bike,
cut the skin so you have enough to wrap it 3" or so around the edges of the
ATV seat and use heavy duty upholstery glue. That would do the trick for
sure. You can even add upholstery tables to the edges. If you're anticipating taking the skin off to clean, you might want to consider double sided Velcro.
It's cut long so I was planning on wrapping it under the pad. I'm going to have to look at it again to see what will be the best method to attach it. I've got a couple options, just not sure yet which I want to go with.
