Theme Silent Wave - Please Read
The font size is MUCH better! You don't have the wide version available to look at yet. do you? I would like to check that out. We definitely need to be able to distinguish links from the text. That is a must.
[quote author=CarlS link=topic=1845.msg12685#msg12685 date=1222022785]
[/quote]
Yes it is up and running "“silentwaveblue_wide (1.1)†check in your profile https://www.triumphtalk.com/index.php?action=profile
A bit of a change here. I was going to have them as twp choices the normal one with the margins and the full screen version. However I have noticed on the version with the margins each side some panels hang over the sides. So I am only going to go for the full screen version.
[quote author=CarlS link=topic=1845.msg12712#msg12712 date=1222063877]
The bluewide looks good. I can certainly live with that. :y115:
[/quote]
Any other little changes you would like to see on this one. I still want to get the view own post at the top. So once we are 100% happy with this one I will start looking at the different colours for the others
Well it seems that it is going to be better just to put this on hold for now until SMF V2 has been released. Looks like there will be quite a few changes to how the themes work so I will just wait until then so when we do this it is done. I will leave this theme up now as it is and will not remove any of the old one that we already have working :y18:
[quote author=Silli link=topic=1845.msg12751#msg12751 date=1222085189]
I'm happy with it as it is.
What happened to "Show Most Recent Posts" link...... regardless if one has read them or not?
:y115:
[/quote]
Nothing it should be as it was, what theme are you using?
