Theme Silent Wave - Please Read
Please have a look at this theme as I am thinking of changing this to be our base theme for the forum because of the coding issues I am having with the other themes. What I would like to do is have different versions of this theme for us to choose from as we have now. So please have a look at this theme and give me some feedback on this. What I would like to know is what changes you would like to see (different versions of this one)
So :y138: give me feedback :y18:
Ok changes from my side :y18:
1. The text needs to be a bit bigger
2. I would like to see “my post†under unread at the top right
Hello DaveM
you have xxx messages, 0 are new.
Show unread posts since last visit.
Show new replies to your posts.
Show my posts
The text is definitely too small. It does not fill the screen. The layout is good. I would prefer one that fills out the screen. Can this one be made to do that?
yup, is certainly livable IF you can increase the text size to match the text in the side menus.
If I hit "increase text size in my browser" ( safari ) it increases all the text and the side menus go way oversize.
:y18:
Here are some of the changes we are looking at so far.
1. Post font size to be able to be increased by member say three different sizes selectable by user.
2. Page width changed from current width to full screen selectable by user.
3. Would like to see “my post†under unread at the top right as you have on your site
4. Remove the water effect from top and bottom panels and just have it plain
5. Need to be able to install the theme in 5 different colour schemes or have colours selectable by user.
6. And most important it must be compatible to be upgraded to SMF V2
Colours will be
1. Original as it is now
2. Light Blue
3. Silver
4. ????
5. ????
So we still have two colours to fill so what should they be :y18:
I'm not very particular about what Theme I am using, but just to make you aware...
When using the Silent Wave theme, text links remain the same color (gray) as the text in a post so you can't really tell what words are links. Browser preferences are overridden by the Style Sheet so they don't get underlined either.
I assume this gray is used because the topic names you click on will be gray to fit the theme, but it makes seeing links inside the text of a post impossible.
