old flyblown
Hello. We have just purchased a1977 T140 Bonneville( for the lovely Mrs Old Flyblown). Its been sitting around unused for sometime. Motor starts up and sounds sweet. However it seems impossible to select neutral when engine is running. Also hits neutral between the gears when shifting. I pulled the clutch apart and fitted new clutch plates as the old ones were a bit worn, set the clutch so that it spins true and am dissapointed the problem has not improved.Still wont select neutral with motor idling,false neutrals changing through gears. Am I missing something here? any advice appreciated.
