I am not convinced its the chain tensioner either.....just wasn't to check it over to rule it out.I'd be suspicious of it being the tensioner. The tensioner only pushes against the cam chain slipper to hold tension on the chain. Years ago I changed out my Rocket III airbox for pod filters and on my first drive down the road heard a herd of crickets from the motor's engine bay that hadn't been there before. Turned out it was valve train noise was coming thru the pods but had been masked by the snorkel and distriburtion header from the airbox. If you're hearing a ticking noise it's likely the valve train opening and closing with more gap between bucket shim to cam lobe cold that disappears when the motor is warmed up. Not saying that's 100% it, but from the descriptions I've been reading it seems a lot more likely than a cam chanin tensioner.
If it were slack valve gaps I would hear it soon as the bike starts up.....but I dont....I hear it maybe 30secs after a cold start......lasts 2 to 3 mins a goes....started at 500 right after first oil change.
Valve gaps was one of the first things I checked....exhaust gaps were to big....re shimmed.....made zero difference.
Spoke to lots of owners with the same prob....and it started after the first oil change.
Heard the put thinker SAE 30 running in oil in these motors when new and warn do not leave in longer than 500mls.
The thicker oil could be connected.
Found out recently.....Triumph Have sent out a circular to dealer and amended the hand book....when changing oil refill the motor before fitting the oil filter.....as air lock can form in lube sys.
Something is going on.....I wonder if air gets tapped in the sys.....maybe its stuck there.
causing probs......Triumph thought it import enough to do what they did.
Anybody any ideas about that.
Something I have never heard of before.
