Removing Rear Baffles From Stock Pipes; Applies to Bonneville/T100
First start your bike from cold, let it idle and dont rev till the cooling fan kicks in, then let the fan run its cycle untill it switches the fan off. Then turn the bike off. Turn the bike back on and take it for a ride apparently this prompts the ECU to adapt to any changes in the engine like exhausts etc.
Failing that you can take your bike to the local dealers and they will remap it for about $50 here in Australia. If you have something like a two into one exhaust they can remap the bike to suit an Arrow exhaust as most of the two into ones are the same or very similar.
Hope this helps.
What is a 20 minute tune, I've 'adjusted' the baffles and fitted a K and N filter on my 2011 865 Bonny, just interested...
On a 2011 Bonnie all the 20 minute "Reset Adaption" does is calibrate the TPS to the tune. It will not make a tune run better at anything other than low throttle, low revs and that's only if the tune is correct for your modifications.
