Hope you get an answer...let me know if you could please.I will leave it there, that's the plan!
No problemHope you get an answer...let me know if you could please.
I bought a stethoscope a few months back....I could hear the injectors cackling....I will listen again see if it stops as the motor warms.OK, now I did a bit of listening with a stethoscope. All the Rocker area are just swishing along nicely.
Then I touched the injector body, and there was the clacking sound!
It must be the solinoid rattle, I believe this happens when the ecu doesn't demand enriching fuel during the warm up and they rattle until warm.
I suspect the ecu is updated after the first service to allow a leaner mixture. This is the only explanation I have but maybe if others can chime in, then I'll be interesting to hear.
Not yet, as I never ride on salted roads. Made that mistake years ago.I bought a stethoscope a few months back....I could hear the injectors cackling....I will listen again see if it stops as the motor warms.
Has the engineer not looked at it yet.
Your like me....recently dug out my old BSA Bantam....using that till its all gone....not so many shiny bits on it.Not yet, as I never ride on salted roads. Made that mistake years ago.
I've got a Hymalanian, but ride it in all weather's but not even that will see salt unless it's an emergency.Your like me....recently dug out my old BSA Bantam....using that till its all gone....not so many shiny bits on it.
Decided this year....save being backless for 3 months I would use the Bantam....only after lots of rain and no fresh salt....on dry roads only.....other wise it sits there one year to the next.I've got a Hymalanian, but ride it in all weather's but not even that will see salt unless it's an emergency.
OK, sounds a different area to mine.Decided this year....save being backless for 3 months I would use the Bantam....only after lots of rain and no fresh salt....on dry roads only.....other wise it sits there one year to the next.
Just got the Bonnie out.....had a listen with the stethoscope.....
Injectors do give a very regular ticking noise.....but I can here the engine tapping sound in the background....slightly irregular.....not in time with the injectors ticking...
If I put the scope on the left side rocker cover....I hear it through the scope.
So to me its not injectors.
The Castrol SAE20/50 has made the Tapping sound more subdued.
One of the first things I checked....my theory....rocker arms as they have some free play....ali head warms up quickly noise goes.OK, sounds a different area to mine.
The valves on mine were very quiet. The only noise was the injection.
Best get the tappet gaps checked.
Went along to my local Triumph shop today to book the bike in for next week.One of the first things I checked....my theory....rocker arms as they have some free play....ali head warms up quickly noise goes.
Isn't your tapping like mine...a bit irregular?
That was one of the first things I suspected....still a possibility....but why would it only show its head immediately and dropping the running in oil at the first service.....didnt yours do that as well....I know it was like that with others I have chatted to.Went along to my local Triumph shop today to book the bike in for next week.
Chatting to the mechanic there, said that it's mainly the cam chain tensioner. So we will see!
Running is oil (SAE30) Mineral is a lot thicker than the normal fully synthetic 10-40....it would take longer to get in the quite small hole in the tensioner body....and prob take longer to leak out engine stopped.The mechanic said that due to different oil used, the oil has to tension the tensioner, and the 'running in' oil does a better job in getting to the tensioner quicker.
Service guy has a xe, he said they make a noise after starting but he's not worried.
Was wondering if you had made any progress SB.Bikes been at the dealers for a week and I've had a call to go and collect her on Saturday.
They replaced the steering lock assembly. They have checked the valve clearance and said nothing now is making any strange noises. I'll be judging that tomorrow.
Does your tapping disappear once the engine is warmed doesn't it like mine....for that reason I do think its not a major problem.....more of an annoyance.I do not hold my breath on this one. If it goes the same and it's annoying, I'll sell it.
