Magno
Hello bikers,
I need advice!
I think I have an oil pressure problem. I recently changed the oil with the correct amount (as it was very cold here I used a thinner 20/40 oil) but noticed a few days later that the oil level in the frame had risen right up to the filler cap. So I drained some off and found it had risen again after riding it the next day. I checked to see if it had dropped by the next morning but it hadn't. The pump appears to work fine as there is a steady stream coming out of the pillar just inside the filler cap. I have also noticed a small amount of oil (and some water) coming out of the oil beather pipe that runs along the back mudguard. I've only been using it on short journeys as I need to get this sorted before going far.
Any advice gratefully received.
Hoping you are all well and warm.
Magno
I need advice!
Magno
