Yes, that is correct. The service intervals are in 6000 mile increments. Because I used to ride in dusty, dandy conditions, I changed my own oil and filter at 3000 miles - and checked or cleaned the air filter. I have a Uni air filter. I now change my oil and filter at 4000 mile intervals. If you change your own oil, be sure to use a synthetic motorcycle specific oil with a JASO MA rating. The JASO is the most important. You do not have to use the overpriced Triumph branded oil. I caution against using automobile motor oils. Automotive oils contain friction reducers than can cause wet clutches in motorcycles to slip.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
