Home Made Carb Balancer Gauges For £25
shanered6
Tigers rule the wild !
Staff member
ok there are plenty of home made carb balancing gauges out there including using water bottles , but I've gone the more conventional route using gauges .
Now you can buy a set of four of these gauges of eBay for £19.99 !
Allso you get the adapters to screw on to the gauge so you can fit rubber hosing to them as you can see in the top left of the pic ,Now I bought my length of rubber pipe from my local motorist day centre for £4 for two metres , and that's all you need to make them up !
Now all you need to do is attach them to a peace of ply wood or any stiff surface that will hold them together , put as many or as few as you need together (in my case 3 ) to match your bike and your ready to go .
This is a pic of them set up and on the bike !
Now some of you are going to curse me and say they don't work ! Why you ask ? It is because when you start the bike up the gauges will bounce around all over the place making it impossible to read them .
But what you have to do is set the revs of the bike up around 3000 to 4000 rpm and the gauges will sit flicking between 5 and 10 on the gauges making an ark ! So all you have to do is see if they all ark in the same place on the dial if not adjust as needed .
And don't forget to block the carb breather pipes !!!
Cleaver, and you've saved a few bob as well. Here's my set I bought a few years ago. I took the cowards way out. It's amazing what you can do yourself, if like you, you just take a step back and think " Now how I can I do that ".
images
TUP
Ye they've shown me that the super 3's carbs are almost spot on so I've left well alone and am trying to hunt down the flat spot issue else were , and this is another cheap way of fixing your carbs up !
I decided I would try this before I stripped the bike to clean the carbs again and it worked FANTASTICLY WELL !
I bought a tin of Granville carb cleaner for £3.99 ! So I drained the carbs down then sprayed the cleaner down the fuel lines till the carbs were full , left it over night then put the fuel tank back on (not draining the carbs of the cleaner ) connected the fuel lines back up and ran the bike .
Well it still missed at the bottom end so I left it run well I cleaned up the workshop , then I heard the fan kick in and I thought ok that's long enough went to I and reved it up and the flat spot was better and as I revved it more and more the flat spot got lower and lower down the Rev range till it was gone !!!!
I can't wait to try it out without the flat spot and it just goes to show that some of this cheap fix stuff really does work !
I think this is going to transform the ride of the bike and will make it much easier to ride in the town and two up .
