heli coil?
tgrath
Ok, ive taken the motor out and apart,68 650 bonnie, found a good british bike machinist, while taking apart i found that the clutch cable thread going into gearbox cover is striped, is there a heli coil option for this or do i need to replace cover? if so size? thanks
It's not critical to have it threaded as you can simply adjust the length of the cable in other places/ways. But you can use a helicoil if you really want to. I'm sorry, I don't know the exact size off the top of my head. Just take the cable end with you when you get the helicoil.
-- Posted with TapaTalk
The Seeker is correct, just clean up whatever remnants of threads are still intact and perhaps apply a dab of JB Weld before re-inserting the abutment.
Once it's in place, it isn't going anywhere, being captive by the cable itself. remember to use a rubber boot to keep out moisture.
Write your reply...
