Headlight LED Replacement Bulb
I have a 2022 T120, which is the best LED replacement bulb for that bad OEM one??? Or would this be better if you got the big bucks?
https://www.ajcyclesny.com/product/motodemic-led-headlight-upgrade-triumph-thruxton-r-1200
Yea, I don't have 800 for a headlight but I know a guy who got that one and loves it, lives out and afraid of deer and things at night. I just got a 30.00 H4 LED bulb off Amazon and am pretty happy with it made a big difference on low. It fit perfectly plug and play pretty much.
https://www.amazon.com/gp/product/B071Z7RHYM/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
It all depends on how much riding in the dark hours you do. Remember "A gentleman does not motor about after dark." Joseph Lucas (1842 - 1903).
Joking aside, if it’s daytime visibility you are after swop your Halogen bulb for an LED one. Brilliant white light which looks a lot better than the yellowish Halogen output.
If you are looking to improve your nighttime illumination by all means do as above but don’t expect a good dip and main beam. This is because the reflector for the Halogen bulb is not suited to the new LED light source.
To enhance night vision why not go for a pair of Denali driving lamps? Not cheap but probably better than the alternatives.
Hello - I’d definitely like better daytime visibility and so my thanks for the advice! But when I followed your link, Amazon claims that unit will not fit the 2022 T120 Black…are they incorrect? I’ll grab one if you advise that it does indeed work? Many thanks!
Hey well that's strange I double checked that's the one I got and it says it doesn't fit my '22 T120 but I'm sure it did when I bought it but anyway it does fit perfectly anyway.
Check your owner's manual, it lists the bulb type by number, it most likely will be an H4. Buy the LED that is listed as H4 (or what your manual lists) and it will fit in the reflector, getting the whole mess back into the shell maybe hard if the LED has a fan on it..
