Fog Lights
Beamer326
I am hoping for a better answer thasn what I could search.
What are yoyu guys using for fog /acc lights? Once I get my highway bars on, I want to add some. What works good with the extra switch on the T birds? Is it hard to wire? Not interested in the 3 mode stuff I am seeing on Amazon. Just some good yellow lights for fog. I find the two headlights on the storm are just fine for everything else.
I have thought about the Denali lights quite a bit for my Tiger. Can change lens to suit what you want. Lots of various kits to choose from. Not cheap, but most good stuff isn't.
On my Tiger 900 I rewired the fog lights to be controlled by a separate bar switch. I mounted LED Moto Lights with yellow tint on the calipers controlled by bar switch. I mounted Denali S4 2.0 to the protection bars. When the bar switch is turned on, they are only activated when the hi beam is on via a relay.
All of these are powered through a fuse block and relays. I believe the bar switch is a Show Chrome that I repurposed from a previous motorcycle. There are several choices for switches.
