Micksan
I recently messed with my rear end. I have the special tool to align the rear wheel, and a digital, caliper to check it. It was dead on . both sides read the same.
After all that I took it out for a ride. Heard a rubbing noise. After a lot of searching , it turned out to be the drive belt was rubbing on the outside wall of the belt housing on the wheel. Pushed it while turning the wheel and it moved off. the rubbing sound went away.
Started the bike ( Bike off ground) , the belt went right back to where it was. Stopped down at the dealer, and the have a need one on the floor. that belt is setup the same way . Dealer had no idea, and workshop manual says nothing.
My Indian classic has a similar system. The workshop manual says to keep it off the wall. Need to see teeth on both sides of the belt.
