Booster Plug Review
I am sure I read recently that the ethanol used in gasoline is now the same price as the petrol portion . We are in effect paying more for less and the science has totally debunked the false E advantage long ago . JFL
Depends how much you are paying for your hydrocarbons. Average price for E10 on the eastern side of the Atlantic is around 1.48GBP/2.40CAD per litre, based on that price E0 would be about 1.80GBP/2.92CAD per litre. Although....late last year E10 was a fair bit more than that!!
I know I’m jumping in late. . .I have a Booster Plug and it does make a big difference. Not perfect but no long thinking about lurch avoidance. I will say I got the same effect by putting the bike in Rain Mode in city stop and go traffic. I don’t know what impact it has keeping the bike set to rain. . .but it did help a lot in the city before I got the Booster Plug. . .now I don’t think about it anymore.
That makes sense . What ever works for you is good . Be interesting to know which WC Bonnevilles had the stalling issue safety updated map . If yours had it that would be a natural IMO and keep the plug too .
I have fitted a " Booster Plug". On the roads I ride on here in New Zealand we have a lot of tighter 2nd gear type corners on all sorts of terrain (uphill, downhill etc. ) where rpms drop back to idle or close to it as you pull up for the corner. My T120 has always suffered from the much reported bottom end flat spot and has not been nice to ride at low engine speeds and I have got into the habit of holding a few rpms on with the palm of my hand on the throttle along with a little bit of clutch slipping out of tight corners at times
I don't know what a booster plug is, but this is lugging the engine, accelerating from very low revs. Don't know about modern bikes, but on classic Triumphs it's risking holing a piston, or worse.
I thought clutch-slipping was normal way to ride.
Sorry , I was in such a rush to spew some of boundless garbage that I missed your lunching comment . The decat moved the lurch point down from 2000 rpm to 1500 on my TTR , much smoother to sneak around town , runs cooler , 5% more power and IMO sounds better . I got the Motone unit because of it’s build quality , it’s prettier too and it’s made in the UK where my ancestors came from .
There’s a lot of WC Bonnevilles out there with just a booster plug and a decat installed . It’s probably the best performance improvement for the buck available anywhere..
No it’s not lugging the engine . It’s more like when your slowing up in first gear for a stop sign and when you get down to1800 rpm it gets into the chain snatching thingy and you must pull in the clutch or it stalls or does the hebegeebees . Lugging of course , accelerating up a hill in high gear , at 2500 rpm , wide open throttle , two up . Also wears piston skirts leading to that slapping noise even fractures . Many modern pistons for all intents and purpose have no skirts at all , just big aluminum hockey pucks with rings around the edge and probably a wrist pin underneath still . Even Chevrolet V8’s suffer the malady as they search for better fleet average fuel economy . Do wonder how much energy it took the manufacturer to deliver and install the new engine in my , just a few months old , car years ago .
Open class motocross bikes must use such pistons to produce their 60 or so hp from 450cc’s . Their engine life is measured in hours instead of miles . No amount of lugging avoidance can save them .
Ok. Don't get that on my 51 year old engine. Guess things have gone backwards engineering-wise since Edward Turner passed. ¯⁠\⁠_⁠(⁠ ͡⁠°⁠ ͜⁠ʖ⁠ ͡⁠°⁠)⁠_⁠/⁠¯
Get 60mpg too, in this 750cc.
OP did state though...
. I noticed the change immediately on leaving my garage and riding up my driveway (slightly uphill) , I didnt have the slip the clutch and coach the bike up the drive way with a few revs on!
That's lugging engine, I'd say. Not extremely as in two up, up hill, fast, hard acceleration. But there's a suggestion there of taking off at idle revs, might just need some care not to overdo it.
I'd think slipping clutch is normal way to do this low speed riding.
Solo
If you go back to the beginning of this thread and read forward you will know a lot about a power booster . It basically just tricks the ECU into thinking it’s colder outside and richens the mixture .These new bikes are are super lean , emission
standards , and love it when some one gives them more fuel . In fact they are so happy that they just work much better. Happy wife / happy life .
