I'm showing my age, channeling the Beverly Hillbillies theme song.
Apparently I overfilled Barney's oil tank a few weeks ago when I topped it off. There's no line at all showing, although when I let him rest on the side stand, the oil drains out enough so that there's a line in the middle of the view port. (I followed the directions for running the engine, then letting it rest, standing it upright and checking.) I hope I haven't damaged anything.
(Don't get me started on how much I dislike that method of checking the Bonnie's oil level. Damned dangerous, awkward, and unseemly!)
I resisted the temptation to just ride again anyway, and rolled him back into the garage.
Can any of you experts give me a tip on how to remove a bit of oil? Have you had luck with threading a skinny tube into the oil filler area and using a suction bulb? Should I just bite the bullet and tweak open the oil drain bolt to let a little bit out?
I don't really want to do an entire oil change, although maybe I should just do it anyway. I didn't do it when I first got the bike 6 months ago; I don't know if the dealership did it when they bought it used. The bike has 2500 miles on it and the oil is still decently light brown, not nasty looking or dark.
Reading the Haynes service manual, page 1-11, it says to replace the sealing washer on the drain bolt when the oil is changed. Do I have to do this if I'm just letting a little oil out? I'm not planning on removing the bolt entirely, just cracking it open to let a bit of oil out.
Finally, where do I get the sealing washer? Does it come with the purchase of an oil filter or is it a generic type washer?
Thanks, guys. I hated not riding Barney today. It's going to rain (again!) tomorrow.
