Yes...great job!!
It worked!!! The local Triumph place didn't have a replacement bolt and my Bike Bandit order got put on backorder so I went to the local fastener store and bought a 10.9 grade bolt in the correct size. Got the bike back together and the engine sounds fine now. I'm so relieved that this was an easy fix. Thanks to everybody for the help!
Does anyone know if the flasher relay makes an audible ticking noise when it's working? The turn signals aren't blinking and I'm wondering if I have a bad flasher relay or just a bad ground somewhere.
And my bike falls within the VIN range.OK I'm reviving this one because I have a 95 thunderbird that has a weird clanking noise at idle. So this could match. I've been through everything. Rebuilt carbs, valve adjustment, timing check. I am new to wrenching and I was hoping for some clarification on the process for this check. Did the clutch need to come out? The haynes manual is suggesting so to get to the alternator/starter drive shaft. It's either that or I have to split the crankcase, which does not seem to be the move here. Any help us greatly appreciated!
That would be super helpful! Thank you!Try posting this in the 900 T'bird sub forum, May get more attention. Can move it if you like.
https://www.triumphtalk.com/forums/thunderbird-3cyl-900-885-legends-adventurers.89/
