gumpt1oo
Scrambler
Not trying to tell you guys how to suck eggs, thought it may be useful to anyone new to bikes.
Static sag is the amount the forks compress under the weight of the bike and rider.
To check this, raise the front wheel off the ground so that the forks are fully extended.
I then put a piece of tape around the fork leg as a reference point, and a cable tie around the fork leg tight to the dust seal.
I then measure the distance between the cable tie and the tape and record it. ( 66mm)
Now sit on the bike, with both feet off the floor, then measure the distance between the tie and tape again. (22mm)
So the static sag is 66mm -22mm = 44mm
I like the front to be a little stiffer, but the Bonneville and Scrambler do not have any pre-load adjusters on the forks. So I bought some 36mm diameter x 2.7mm thick stainless steel washers that fit inside the fork tubes.
Removed the fork nuts and fitted 2 washers (5.4mm) to each fork tube and refitted the nuts. Then repeated the measuring process.
With the washers fitted the measurement is 31mm, giving a static sag of 66mm - 31mm = 35mm.
This gives a firmer ride with less fork dive under braking.
A very cheap and easy adjustment to make.
![102_0154.jpg](https://proxy.imagearchive.com/6ab/6ab7e35ba3e00b9e754350bb7fce9323.jpg)
![102_0155.jpg](https://proxy.imagearchive.com/842/842cf03091e801864c1002f3937da204.jpg)
![CIMG4274.jpg](https://proxy.imagearchive.com/f43/f43b470a0de862e435aabc7bcf946bcc.jpg)
![CIMG4278.jpg](https://proxy.imagearchive.com/9bf/9bfb560796814ecb8539a3abeba09662.jpg)
![CIMG4279.jpg](https://proxy.imagearchive.com/1b9/1b9102f8f41bfec05c9c27c6b68d6b64.jpg)
