2018 T100- Noise Under The Seat
catch210
Hello, yesterday I picked up 2018 t100 , not sure if this noise was there before I brought home or did it start after I washed the bike( its dirty). When I turn on the key without starting it, I can hear a noise under\near the seat (air box). sounds like a stuck fan or air leak from a hose probably neither. I may have to take the area apart to inspect.. maybe someone have experience with this. I will attempt to attach a video.
If you unplug the fuel pump or pull the fuse for it that might narrow it down. Normally it will only run for a few seconds to build pressure then stop.
Second this. When you turn on the bike, the fuel pump starts, and mine does sound a bit like a fan.
Thank you for confirming! I look up some other post and found this is typical noise and some say it happens when the bike has been sitting for a while or happen when the fuel is 1/2 tank.. I will monitor it the sound ...but feel better (not happy) this is not unusual for Triump's. I have a 2012 tiger 800 and it does not make any sounds like this after it primes.
I will update once I get it on the rode.
I should have watched your tweet video. That is the exact sound mine makes when first turning on. I am not sure how long it lasts as I start mine usually within a few seconds, and engine/exhaust noise overrides the fuel pump sound.
