WTaute
Hi everyone
This is something I would like to share and give my opinion on this topic...I've build quite a few race engines and I don't understand why people are so concerned about valve clearance check...If you look at the engine head you will notice that the valves will ,with time, pull into the valve seat, which is normal, as this is happening the valve actually move further away from the piston when it is opening because of the wear, so no it will not cause valve to piston damage, but the problem is that it will become harder to start as the valves are partially open and you can not build pressure, this also occur mostly when engine is cold, so my opinion is when you start getting hard start issue then you do a valve clearance check...one thing I would highly recommend ,never go below your minimum shim thickness, you stand a very good chance to break the valve and cause mayor damage to the engine...any input to my view are welcome.
