Thanks for that.if you can, yes. triumph had worn machine tools, and so fitters would hand-select timing pinions that fit well during assembly.
if you mix em up, there is supposed to be the possibility of more noise and maybe? a bit more backlash.
but that was then. i mix em up without anything exploding these days.
if you have a buch of gears, its possible you may have some with keyways that were machined a bit off. these are valuable because they allow timing adjustments a bit more precisely than what the average gears offer. but most all the ones i measure are pretty accurate.
No, the cams were still in the cases when I got them.^^^that is odd. the cam pinions are an press-fit on the cams., and you cant take the cams out without removing the cam pinions. did someone remove the pinions, take the cams out, and then re-install the pinions on the bare cams? if he did, its a good bet that the pinions go with those cams.
if something else is going on, i wouldnt worry about maintaining a matched set. its a good thing to do if you are lucky enough to buy some together-- then mark them and use them that way. but to be honest, after this many decades, the ordinary wear on the cam pinions is likely to be greater than the closeness of fit of any pair when they were new.
T140 cam pinions interchange with T120, but have puller holes and different marks.
Thanks for that!Don’t forget that the timing cogs have a Hunting configuration which means that every tooth on one cog will eventually mate with every valley in it’s adjacent cog so over time any slight mismatch will bed in.
