This subject recently came up at a club coffee gathering.
I was a little shocked at the view of some (cheap skates) that a motorcycle tire is good until it's worn out.
Sometimes it's a little hard to read through all the hype over this subject, but from what I have learned over the years it's not recommended that you ride on motorcycle tires that are over seven years old.
Some say that's just a ploy by the tire companies to get you to buy new tires, but in these days of liability and $$$ law suits I'm not so sure about that.
I use seven years as my guide regardless of tread wear. After the seventh year it's time for new tires. Tires deteriorate and harden over time, and since we have barely the size of your hand touching the road, I like to err on the side of caution.
I just did a scan of all my tires and they are all in the 6-7 year range this year. Some are worn to the point of replacement this spring anyway (rear tires), but next year I'm going to replace the rest.
I don't mix and match and always use the correct sizes; same brand and construction front and rear.
The manufacturing date of the tire is stamped on the sidewall and is easy to read.
Example: 2109 is the 21st week of the year 2009.
