A few weeks ago got my 140v back together and she started second kick and ran smooth at idle. Since then the idle has been rough and now cant seem to keep the left cylinder running. I put on brand new Amal's and spark plug wires over the winter. Things I have done today are drain the tank, rinsed it and put fresh gas in, and new plugs. I have adjusted the air mixture screws to 1 1/2 turns out, and played with the idle adjustment screws as well. Also checked the synch. on the cables/slides and they seem fine.
She starts easy, and runs ok if I keep the idle higher. Just ran her up and down the street, and after 100 yards or so sounded and felt like I was running on only the right cylinder. Got back to the garage and pulled the right plug boot off, and the bike immediately died. So I think my issue is directly related to the left side. I also pulled out the air screw mix screw on that side and shot carb cleaner in there, even though it is a brand spanking new carb.
I am starting to run out of the easy fixes. Any ideas?
