Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Normal
While it is not impossible for a pressure problem to be caused by the plunger pump, it runs in oil and the correct 4 valve pump on a 79 twin was designed to negate a problem in any one valve. So simply replacing the pump without testing the existing one - stripping and inspecting its components if desired - could be an expensive solution for something that rarely causes a problem ...
