Oldmans Trophy
Hi ..... just had tire valve replaced and the speedo packed in on my ride home. Its still clocking distance.
I have checked the cable is ok and having removed the clock itself I've used a drill ..... when its in reverse (counterclockwise) and the speed indicator operates as it should ..... when I use the drill to drive it clockwise the speed indicator doesn't move. Is this normal for a magnetic speedo ?
It seems coincidental that the problem arose after the wheels removal and I'm hoping the issue is with the hub
