My T100 is overdue for the bi-annual vehicle inspection so I've been going over it and doing all the checks myself.
The front tire is worn down to the wear bars and I'm quite certain that it wouldn't pass inspection. It's also seven years old and should be replaced anyway, so I have a new one and a new tube on the way which should be here on Tuesday.
I've already removed the front wheel and cleaned it up. I'll take it to a dealer to install the tire and balance it. It's well worth the fee to have a pro do it.
The rear brake pads are looking very thin and I'm also sure they wouldn't pass inspection either so replacing them will be my job for today.
The brake caliper on these bikes is mounted on the bottom of the disc which makes it very hard to work on. To give me more room I removed the muffler (silencer) and while I'm at it I'll change the brake fluid.
A pro would have a bike lift and probably wouldn't remove the muffler, but I'm an amateur with no lift
