[/TD] [TD="class: msgtxt"]Well, I finally decided to lower my shift lever and rear brake pedal on the T-100; the shift lever was, naturally, a 5 minute job, but then I went to the brake lever. If I can ever meet the sadistic cretin who designed that bit on insanity, I have a few choice words for him or her. I was determined not to take the footpeg off, so I bought a cheap set of "flare nut" wrenches in hopes of getting in between the frame and peg bracket to loosen the nut. No such luck! Even grinding the sides of the wrench thinner didn't work. Soooo, I gave in and pulled the front sprocket cover off, hoping it would fit that way. No such luck! Now, at my wits end and ready to give up for the time being, I went to my tools and saw a set of "crow's foot" metric ones that I'd bought so long ago that I can't remember why (not that age has anything to do with it, you understand). These NAPA ones were shaped almost like the "flare nut" ones and , lo and behold, the 12MM one did the job, albeit with a "wobbler" adapter on the breaker bar. It was a bloody tight fit in there and, as well, I had to use a pair of pliers with some tape wrapped around the jaws to keep from marring the brake rod, as it didn't seem to want to turn easily. Anyway, the pedal is now where I can slide my foot on it quickly, and a lot more comfortable to use. This is presented purely for reference purposes only...............don't try this at home!!!
Sometimes, the "village idiot" wins one: Jim
[/TD]
