Dschief
I bought a BC relocate bracket to move the ignition switch from the headlight bracket down to frame. I didn't think it was going to be as big a deal as it has turned out to be.
Removing the switch from the headlight ear was not a problem. Installing the switch to the bracket was no big deal, but the screws bottomed out before the switch was tight in the bracket. No big deal, I just used some small washers to shim it.
My big problem is the wiring. The kit comes with new frame bolts and the bracket, and no instructions. If anyone has installed one of these kits, or a similar kit, how do the wires need to be routed? The only thing I can see is; the entire ignition switch wiring assembly (including the connector that is currently in the headlight bucket) need to be moved to outside the bucket in order to give me enough wire to attach the switch assembly to it's new home. Otherwise, the wires will be too short to allow full steering lock to the right.
Any wisdom or experience on this project will be greatly appreciated!!!!
