Ignition Issues
Rich65
My 2008 Bonneville is having ignition issues. When I turn ignition key to "on" position, bike automatically begins to turn over, even though I am not pushing "start" button. Also, even when engine kill switch is in off mode, bike still tries to turn over when ignition key is turned from off to on. I checked inside controls and it is not wet. Any suggestions guys?
Yes it sounds like your main harness is damaged around the head stock , it might of been quashed or pinched in the steering stops !
I know of two others that did just that and the harness was damaged inside and some of the wires were damaged and shorting against each other , so just check the hardest for any wear or tear .
