How to set Information Tray to show Fuel Range 2018 Tiger XRt 1200
Idaho Tiger
What is the process for setting the Information Tray to show Fuel Range? I hitting the home button, then played with the joy stick and spent 20 minutes and it will not show me the Fuel Tray (the one that automatically comes on when you hit the low fuel warning). I just want to see how far I can go on the half tank I have now to see if I need to get gas before the short trip I'm going to take, and it does not want to show me the Fuel Tray. Does anyone know the process? I could not find it in the manual :-(
Figured it out:
1. turn Keyless Power Switch to On
2. press Up on the Starter/Kill switch on right handlebar to turn on display
3. press Home Button on right handlebar twice to get to black setup screen
4. select Display Setup with Joystick on left handlebar
5. select Visible Tray with Joystick
6. select trays you want available with Joy Stick (indicated by check marks)
Write your reply...
