Faulty low fuel light on Triumph America 2008 EFI
Richard45
It seems my low fuel light is not working. I had the tank off and drained it so it was nearly empty when I turned the key on. The light came on for the test which is normal and then went out. (Should have stayed on I would think). I noticed with the tank off you can remove the bottom part held on by a million screws. Would it be a good idea to have a look in there and see if there is anything I can fix. Is it a simple float system? There is an electrical connector with 4 wires to the tank so I presume 2 for the pump and the other 2 for a float switch. My manual does not cover EFI so the circuit is not much help. Do the carby bonnies have a low fuel light? Any help appreciated. This is no big deal really as I always rely on the odometer but I like things to work as they should.
Well my one does not have a fuel indicator at all so I always just ride on my trip meter and distance. Then again when I did have a fuel indicator I did the same as I never did think they worked that great on bikes anyway. How it is put together on your bike I also have no idea
Easiest way is at the top of the page, 2nd line,4 in, you will see community.
Click on that and then click on member list in the drop down menu.
Locate the person you want,click on there name and there profile will come up.Just under there avatar,2 down on the list you will see 'send private message.'
Click on that and you should be good to go.
Alternatively, if you see a post with the member you want to pm in there,simply click on their name and a drop down menu will appear with the pm option in it.
