Spoolin
Hi all, have a '71 tr6r trophy oil in frame with electric start. Just want to replace the oil pump as I have just installed the 750 big bore kit.
Currently struggling to remove the timing cover and have searched the Web and manuals with no luck. I have removed all the bolts for the timing cover and the starter motor. Also removed the ignition timing rotor that has the taper and is kinda pressed on with the allen key bolt.
Can only pry one side, other side looks as if its still attached by the cogs for the starter motor. Also punched out a pin into the timing case that was holding a shaft the cogs were attached to.
Can upload pics if need be. Cheers
