Diy Ignition Relocation To The Oem Instrument Panel
Turp
Martey, a member on another forum, demonstrated this mod could be done so after some planning I did my own.
It requires drilling a hole 1 1/8th inches and widening it out to 1.200 thousands with a sanding drum in a drill press. The ignition module is actually mounted on a .080 or 2mm aluminum plate that attaches using the instrument panel bolts. It's very straight forward but the biggest challenge is placing the ignition module mounting holes accurately.
