Bonneville SE idiot lights / instrument conversion
Fro5tie
Hi - I am part way through a custom rebuild and have arrives at the instruments. I had planned a new alloy instrument holder and relocating the idiot lights positioned on the right directly below the speedometer.however .... discovered the idiot lights are a sealed unit and cannot be separated to relocate.
So ... does anyone know if there is a plug in alternative or a solution please ? Failing that any recommendations on a different clock would be welcome.
Would a set of thruxton clocks replace ? Ho Would it be possible to connect the rev counter ?
Sorry for all questions just Scuppered at moment as really don't like the offcentre clock and this is an important part of rebuild
Grateful for any advice
Thanks
Steve
The SE model is very similar to a T100 Bonneville, so parts should be interchangeable, including the twin clocks, so that would give you the tachometer and may be relocate the idiot lights.
