This may be the wrong place to post this question .. am just beginning to learn my way around. But, in any case: Am trying to figure out the wiring on my 98 Adventurer .... the start/stop sliding switch disintegrated long ago in the restoration process. But upon completion (sort of) The motorcycle ran for the first week until I decided to fix the instrument lights. Now I have starting problems. Probably because the battery d/c'd because, I think, my 1.5 charger seems defunct. (I had the lights on and off a lot) My larger charger, a 22 year old Sears still works and will charge the battery at 2 amps. So I am trying that now. Am trying to check the clutch neutral switch. Already disassembled the solenoid and it is working ok.
Another question is (and I'll try to find the right thread to post it appropriately), is there any source for handlebar switches anywhere? Or substitutes? Or, can I continue to live without the sliding switch (right side switch assembly)? Also, I gotta learn about rear shocks and front struts... which probably need rebuilding especically given my weight of 225 (hey, I've lost about 25 and working my way down ;-) ) currently, I bottom out on the front and back ... :-(
Thanks in advance for any suggestions.
m.
m.
