Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Normal
I went out to inspect as I mentioned I would, I had been thinking it was the front sensor ,because of the gap, Then looked at the rear for the 1st time and found this. The cable had rubbed raw on the rear tire.I will splice in new wires and zip tie to brake line to keep away from rear tireMight be a good idea for everyone to check if your cable is near rear tire
