Heidenreich12
So I recently bought a 78 Triumph a few months back and have really enjoyed owning the bike. The issue I'm having though is that it has many false neutrals while shifting between gears, and fourth gear can hardly be found, and fifth has never been found.
After doing some research (and coming across this site a few times) it could be the clutch or the transmission causing the issue. The clutch is almost brand new, so I'm thinking that shouldn't be an issue. So I decided to dig into the transmission and see if I could see anything that appeared out of place or damaged. I've pulled out most of the gears and they all seem to be in perfect condition, and everything was oiled up nicely. I've read that it could be caused by the cam plate/ gear selector as well. This is where I get into problems.
Now for my noob question. While most of the gears came out easily, I couldn't for the life of me figure out how to remove the gears that are the farthest into the housing, and this causes me to not be able to get the cam plate out. Is there a special tool I need to get them out? Or is there something I'm just over looking? I've attached pictures below as to what gears I'm referring to.
I thought that maybe the shaft going through the gears needed to be pulled out and the gears would come off the other end of the shaft as it looks like they aren't going to come off the end the others came off of, so I went to take off any bolt that would be holding it from the clutch side.
Currently what the gearbox looks like, and you can see the gears I'm referring to.
This is currently the clutch side (which I'm not sure if I needed this off to do what I'm needing to do)
All help would be very much appreciated, as I'm new to these bikes and haven't been riding for to many years yet and still have a lot to learn.
