2019 Scrambler 1200 Switch Gear Dead
2wheelzen
Went to start the bike today, headlight comes on, screen / instrument panel lights up, fuel pump primes, but bike won't turn over (doesn't even try), and switch gear won't scroll through settings / reset functions. No horn, no high beam (but low beam is on), no blinkers left / right, but hazards do come on. Battery is good, and even put in new battery just to test, same results. Fuses are good. CAN bump start from 2nd gear, and bike runs, but still no switch gear working.
Help :confused:
Thanks.
UPDATE: Turns out that it's a known issue with a short in the left side switch box wires. Was recommended to jiggle the wires, and it worked.
Now to see if the dealer will address, or play the "we can't duplicate the problem" game. Have a feeling I will have to call Triumph corporate to escalate.
It will be interesting to see the result. There certainly seem to be some QA issues coming to light.
