2016 Triumph Scrambler Engine Swap Help
Guys,
my 2016 triumph scrambler engine failed on me at 50k due to a bad oil pump gear. Now I’m looking at doing an engine swap.
I know that the Bonnie/ thruxton engines will not work without some wire harness and coil work but since the speed master is a 270 will it work?
I’ve done a little research and it seems most part numbers line up. Except the inlet camshaft is not the correct part number.
any help is appreciated, trying to get a new engine in before a 2 month motorcycle road trip across the US later this year
