Hi guys,
I have a 2009 fuel injected Thruxton 900 with a completely standard setup, but fitted with Staintune mufflers. I am having a problem getting the bike to run smoothly once warm. Once warm (at about 2500-3000 RPM) I am getting an intermitent miss fire on what appears to be the right hand cylinder. I have changed the plugs and had the throttle bodies balanced. I have also added a bottle of injector cleaner over the last two tank fulls to see if that clears the problem, but no luck unfortuantely. Wondering if anyone can give me some insight on where to go next. Have any of you experienced the same issues and if so, what was the fix? I would really appreciate any help you guys could give.
Thanks Steve
Thanks Steve
